Date/Time: Sun, 24 Nov 2024 20:53:15 +0000
Using Denali on two computers.
View Count: 192
[2024-04-26 07:35:57] |
trad - Posts: 43 |
From other support threads, I can see that I need to pay for Denali twice to be able to get live data on 2 different Sierra Chart instances running on different computers. My question is: I currently have the Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for non-professional trading accounts, which costs a monthly total of USD 37.50. Can the second feed simply be the CME non-professional top-of-book feed, which costs USD 2.00 per month? Also, can I choose which feed I want to connect to each Sierra Chart instance running on different computers? |
[2024-04-26 12:27:04] |
Sierra_Chart Engineering - Posts: 17161 |
No this degree of control is not available: Can the second feed simply be the CME non-professional top-of-book feed, which costs USD 2.00 per month? You can only control, what symbols you are using which then affects what particular exchange would be used: Also, can I choose which feed I want to connect to each Sierra Chart instance running on different computers? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-26 12:27:29
