Date/Time: Mon, 06 May 2024 18:36:55 +0000
[User Discussion] - Alerts
View Count: 78
[2024-04-26 00:55:40] |
legotail - Posts: 9 |
Before I go down a rabbit hole trying to find something that doesn’t exist - somebody please tell me if the following alert can be built? I want to set up a scan for all equities - when a delta bar closes 300 % above its average delta bar in the last 100 bars. (For example). Obviously, the purpose is to be alerted of steep rises or drops in delta. Is this possible? Thank you. Date Time Of Last Edit: 2024-04-26 01:48:01
[2024-04-26 14:38:27] |
John - SC Support - Posts: 31401 |
Yes, this can be done. You would need to add a Moving Average to the Delta Bars that covers the last 100 bars and then check if the current delta is 3x larger than the average.
[2024-05-05 01:50:47] |
Great, thanks for the response. next question is, I simply don’t have the time to get that scan up and running correctly. Would much rather pay somebody to just build it for me. Do you know of any person or company I can contact who can simply deliver what I’m looking for, for a price? Thank you. (or at the very least — a support group, where somebody can spoonfeed the directions to me like I'm 3 years old) ?
[2024-05-05 16:04:01] |
Refer to the following: List of Third Party Sierra Chart Study and System Programmers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-06 08:57:35] |
Perfect. Thanks!
