Date/Time: Mon, 06 May 2024 22:34:58 +0000
Multi-Contract Bracket Configuration
View Count: 63
[2024-04-25 18:08:05] |
User688525 - Posts: 191 |
Hello Sierra Chart, Without using ACSIL, is it possible to create a bracket order that will enter orders (Entry) 1 or 2 ticks apart? For example, instead of entering 20 contracts at the same price, can 5 be entered at 1000.00 (arbitrary price), another 5 at 1000.25, 5 more at 1000.50, and the remaining 5 at 1000.75? To clarify, using the example above, the intention is to click 20 contracts on the DOM at 1000.00, with the orders automatically placed at 1000.00, 1000.25, 1000.50, 1000.75. Thank you Date Time Of Last Edit: 2024-04-25 19:04:07
[2024-04-25 21:21:54] |
John - SC Support - Posts: 31409 |
There is not a way to do this without using ACSIL.
[2024-04-25 22:01:11] |
Thank you for confirming.
