Date/Time: Tue, 07 May 2024 01:50:31 +0000
Package 11
View Count: 67
[2024-04-25 16:46:58] |
User710829 - Posts: 5 |
I’m an interactive brokers client in canada looking to trade through Sierra chart. based upon some research, for depth of market and footprint charts it looks like I need package 11. My question is, does this include live trading or are there any other fees besides the package 11 cost that i must incur? thanks. |
[2024-04-25 17:50:45] |
John - SC Support - Posts: 31419 |
This is correct. In particular, in order to get the Numbers Bars (footprints) charts. Refer to the package information at the following link: My question is, does this include live trading or are there any other fees besides the package 11 cost that i must incur?
The only other fee that might apply is for exchange fees. If you get the data from Interactive Brokers, then there is nothing else you need from us (Sierra Chart). But if you want to get the data from our Denali Exchange Data Feed, then you will need to set this up and pay the exchange fees. Refer to the following: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-25 20:46:56] |
exchange fees - you’re referring to the actually data package to receive the data to fill these charts? Also, I should’ve asked first. as a canadian interactive brokers client, am I able to trade live in sierra chart? it’s shows roughly $49/month for package 11, will this not have live data unless I buy the denali package? Just a little confused. |
[2024-04-25 21:45:28] |
Yes, this is correct. Also, I should’ve asked first. as a canadian interactive brokers client, am I able to trade live in sierra chart?
We do not have any restrictions on this. We do not believe that Interactive Brokers does either, but we can not say for certain about them. it’s shows roughly $49/month for package 11, will this not have live data unless I buy the denali package? Just a little confused.
Package 11 costs $46.00 per month. You do not "buy" the Denali package, you just decide which exchanges you need the data for within our Denali Exchange Data Feed and setup (and pay for) those exchanges. You will find the pricing for the exchanges at the following link: Denali Exchange Data Feed: Supported Exchanges (Exchange Fees) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
