Date/Time: Sun, 24 Nov 2024 20:50:18 +0000
How can I disply General Settings: General2?
View Count: 199
[2024-04-25 15:52:41] |
User367161 - Posts: 10 |
Hi. Reading through the manual (about scaling and scrolling) some of the items seem to be set by "Gernal2" When I open General Settings, I only get *General* but not General2. A search on your site renders no results for "General2". So, how can I display this? Best regards, Andreas |
[2024-04-25 17:34:05] |
References to the "General 2" tab are old. We have a new window with different pages. Exactly what setting are you trying to find? Also, there is a search option at the top of the settings windows, so you can do a search for the particular setting you are looking for. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-26 07:06:11] |
Thank you. I'm trying to get an overview of scrolling and scaling charts. In particular, I want the vertical scale to easily toggle between automatic scaling (fit the screen) and manual scaling (i.e. I "grab" the scale with the mouse and enlarge or deminish it). Best regards, Andreas |
[2024-04-26 12:26:24] |
Sierra_Chart Engineering - Posts: 17161 |
For complete documentation about this, refer to this page: Chart Scale and Scale Adjusting Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
