Date/Time: Sat, 04 May 2024 22:22:22 +0000
Copy shortcut menu / tool configs to different instances
View Count: 43
[2024-04-25 09:45:23] |
User666015 - Posts: 28 |
Hi All, I currently have a main SC instance and 2 x sub instances, I have created a script that copies study collections from my main instance to the sub instances - the main instance is my 'source of truth' if you like... I would like to extend my script to also copy things like the shortcut menu / tool configurations etc, I can't find the file I need to copy over to the sub instances, is this possible please? Many thanks, Bill |
[2024-04-25 14:55:26] |
John - SC Support - Posts: 31362 |
The file is named 'Sierra4.config' and is in the main installation folder. For information on the various files and what is in them, refer to Step 5 at the following link: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
