Date/Time: Thu, 09 May 2024 01:56:25 +0000
Chart Question Please
View Count: 52
[2024-04-24 18:10:27] |
User495462 - Posts: 1 |
Dear Team - Regarding the attached chart, I want to create white space on the right side of the chart. How do I click and drag the chart to where I want it in the chart window, whether to the left, right, high or low? Thank you!
tmp_1713981308_Screenshot 2024-04-24 082653-SIERRA TECH SUPP.png / V - Attached On 2024-04-24 18:10:12 UTC - Size: 29.82 KB - 18 views |
[2024-04-24 18:12:40] |
John - SC Support - Posts: 31480 |
To click and drag the chart use the "Hand" tool. Refer to the following: Chart Drawing Tools: Hand Also refer to the information for the following setting that affects how the Hand tool works: Chart Drawing Tools: Support Vertical Scaling/Movement With Hand Tool (Global Settings >> Tool Settings >> General >> Tool Options) And if you are wanting to have a constant white space to the right, then you will want to use the "Lock Fill Space" option. Refer to the following: Working With Charts: Right Side Fill Space For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
