Date/Time: Wed, 08 May 2024 16:42:19 +0000
SIM trading not working
View Count: 141
[2024-04-24 17:48:10] |
User143341 - Posts: 9 |
I can enter a trade position on the DOM, but it is not executed.
[2024-04-24 17:48:54] |
John - SC Support - Posts: 31464 |
We need more information. What exactly is occurring? Are you using the built-in Simulation Mode, or are you using the "Simulated Futures Trading Service"?
[2024-04-30 11:35:40] |
What exactly is occurring? Are you using the built-in Simulation Mode, or are you using the "Simulated Futures Trading Service"? WHERE DO I FIND THAT INFORMATION?
[2024-04-30 11:39:19] |
Sierra_Chart Engineering - Posts: 14270 |
Is Trade >> Trade Simulation Mode On enabled/checked, on the menu?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-30 11:39:29
[2024-04-30 11:52:27] |
YES, sim trade enabled
[2024-04-30 12:19:57] |
When you submit an order, what is the Status of the order in Trade >> Trade Orders Window?
[2024-05-01 12:39:28] |
the order is "held"
[2024-05-01 15:13:37] |
You need to change the "Time in Force" to either "Day" or "Good Til Cancelled". Refer to the following: Basic Trading and the Trade Window: Main >> TimeInForce (Time in Force): For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-02 12:04:14] |
Thank you for your help!!
