Date/Time: Sun, 24 Nov 2024 20:21:59 +0000
Having 2 trading accounts working at once
View Count: 257
[2024-04-24 17:35:08] |
kikobgcc - Posts: 1 |
Hello, i'm doing a propfirm challenge right now and i'm using your platform to do it. Now i want to open a personal trading account and trade from there as well, how can i do it? Is there a way of having both accounts opened and trading at the same time on the same computer? Thank you |
[2024-04-24 17:36:59] |
You just need to install a second Sierra Chart on the same computer. This way one installation is connected to your Prop Firm and the other installation is connected to your personal trading account. Refer to the following instructions to install a second Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-25 15:26:56] |
From User: and my current service is enough? I need real live data feeds for both accounts
As long as both installations are on the same computer, then there are no additional fees and you will get the data to both installations. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
