Date/Time: Sun, 24 Nov 2024 20:39:41 +0000
Volume Profile tool customization
View Count: 285
[2024-04-24 17:20:19]
Jaydtrade - Posts: 87
I have DVP tool on my control bar to draw over consolidation areas. I have tried saving the default settings and a few other things but no matter what this stupid thing defaults back to the original and its driving me nuts. How do I permanently make this thing save the settings I want so I don't have to adjust them every single time I draw one on my chart.
Thank you.
[2024-04-24 20:25:29]
Refer to the following for how to setup a configuration for the Drawn Volume Profile:
Volume By Price Study: Step by Step Instructions to Configure the Draw Volume Profile Tool
And refer to the following for how to configure a control bar button that selects the tool and configuration:
Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step
[2024-04-29 14:23:57]
Thanks a bunch got it worked out!
