Date/Time: Sat, 04 May 2024 23:27:41 +0000
CME Lumber Futures New Symbol - IB
View Count: 129
[2024-04-24 14:20:20] |
User624595 - Posts: 183 |
2024-04-24 10:12:34.616 | Trading server did not acknowledge new order | Symbol: LB-202407-CME | TradeAccount: xxxx | InternalOrderID: 21220 | ServiceOrderID: 9636 | Current Status: Order Sent * 2024-04-24 10:13:16.936 | Requesting order status for non-responsive order. Time since last action: 56.4 seconds | Symbol: LB-202407-CME | TradeAccount: xxxx| InternalOrderID: 21221 | ServiceOrderID: 9637 | Current Status: Order Sent * Any issue with the new symbol? Could not execute in Sierrachart, market order sent and hung, eventually auto cancelled without an alert. No issue executing in TWS. Date Time Of Last Edit: 2024-04-24 14:20:28
[2024-04-24 15:17:27] |
2024-04-24 11:16:22.072 | Notice - An overfill UpdateOrder call has occurred. Overfill Quantity: 2. Total filled quantity: 2. Order quantity: 2 | Symbol: LBR-202407-CME-USD | TradeAccount: xxxxx| InternalOrderID: 21224 | ServiceOrderID: -36 | Current Status: Filled *
[2024-04-25 10:20:50] |
2024-04-25 06:17:48.384 | New order rejected - Can't find order with id = 9660. Internal Order ID: 21247. Service Order ID: 9662. Symbol: LB-202407-CME. Account: xxxx* Please help resolve these today? This is affecting live trading execution. |
[2024-04-25 14:06:23] |
Sierra_Chart Engineering - Posts: 14224 |
Can you provide us the Interactive Brokers page, for the symbol specifications for CME lumber futures.
[2024-04-25 14:57:30] |
User584084 - Posts: 241 |
The IB symbol is LBR-202407-CME NOT LB-202407-CME in SC. I just put in a live buy order at 498.00 for LBR-202407-CME using the Chart DOM as a test from SC and it went through to IB TWS. No error messages and the order was not rejected. I am running SC Version 2629 and IB TWS Version 10.25 1k. See attached file below for IB LBR Specs.
Date Time Of Last Edit: 2024-04-25 15:19:31
IB LBR Specs.png / V - Attached On 2024-04-25 15:10:53 UTC - Size: 37.94 KB - 21 views |
[2024-04-25 19:04:45] |
We have updated the symbol settings for this symbol to match the Interactive Brokers contract specifications. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
