Date/Time: Wed, 08 May 2024 04:53:14 +0000
Removing leading zeros from bar time duration study?
View Count: 47
[2024-04-24 10:09:45] |
User664207 - Posts: 9 |
I'm trying to use a renko chart that shows the volume and time duration on the bar, but don't want the leading two zeros for the time duration study. Any way to remove them? thank you! |
[2024-04-24 12:14:08] |
Sierra_Chart Engineering - Posts: 14263 |
No.
[2024-04-24 12:23:54] |
Thanks, I think I solved it using duration in seconds study.
