Date/Time: Thu, 09 May 2024 01:29:00 +0000
Showing P&L net of commissions
View Count: 67
[2024-04-23 19:55:02] |
User864962 - Posts: 1 |
Sorry to trouble you but I've followed all the instructions in the help section and can't get this to work. I have searched the support board and the answer was the same as the help section. I'm trying to display the P&L in the trade window NET of commissions. I have done: Global settings -> Symbol settings -> 'Use Custom Symbol Settings Values' box ticked -> ES?#.CME selected (my symbol is ESM4.CME) -> Round Turn Commission set to custom 4.36 -> Chart - reload and recalculate (also closed it down altogether and restarted)... and still showing 1T/12.50 USD despite 2 contracts opened and closed. Can you advise please? Thank you |
[2024-04-23 20:00:48] |
John - SC Support - Posts: 31480 |
You need to set "Chart >> Chart Settings >> Trading >> Use Symbol Commission Setting in Trade List and Statistics Calculations" to "Yes". Refer to the following: Chart Settings: Use Symbol Commission Setting in Trade List and Statistics Calculations (Chart >> Chart Settings >> Trading menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
