Date/Time: Wed, 08 May 2024 22:04:25 +0000
Access to ETF`s charts
View Count: 64
[2024-04-23 13:46:51] |
User266447 - Posts: 247 |
Does SC offers access to any ETF`s? If yes, where can I find them? |
[2024-04-23 15:48:46] |
John - SC Support - Posts: 31480 |
Yes. Refer to: Denali Exchange Data Feed: US Equities Consolidated Tape Data Feed Notes You do need to update Sierra Chart to the latest version: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-23 22:25:04] |
Sierra_Chart Engineering - Posts: 14281 |
Also refer to this page: US Stock Consolidated Tape Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
