Date/Time: Sun, 24 Nov 2024 23:02:13 +0000
install Vwap on the cumulative volume of Delta Bars in region 2.
View Count: 223
[2024-04-23 12:09:51]
User619826 - Posts: 3
I can't install
the Vwap on the cumulative volume of Delta Bars in my intraday chart in region 2 under the daily chart of region 1, yet I saw on the net someone has a chart with 1 Vwap in region 1 and one Vwap in region 2 on cumulative Delta Bars -volume, apparently it's a chart from Sierra Chart, you can see how to fix it.
[2024-04-23 15:30:47]
It is possible to use a VWAP with the "Cumulative Delta Bars - Volume". Just be sure to set the "Based On" to be the "Cumulative Delta Bars - Volume" and be sure to set the Input for "Base on Underlying Data" to "No".
