Date/Time: Sun, 24 Nov 2024 22:34:23 +0000
Chart Recalculation whe using Spread Sheets
View Count: 217
[2024-04-23 12:08:49]
User787778 - Posts: 139
When using Spread Sheets, the Chart Recalculation Study does not "clear" the chart of all of the "Shapes or Numbers" that have been super ceded. However if one opens any Study's Settings menu and then closes that Setting menu, the super ceded items are removed from the chart.
Would you please add a "script" that would achieve the same result in the Chart Recalculation study.
I have included two screen shots taken using the Time Since Retest of the high and low Study [Number bars calculation 2 sg: 12 and sg: 13]
The only difference between the two, is that I have opened and closed the Chart Recalculation Study Settings.
Thank you in advance.
https://www.sierrachart.com/image.php?Image=1713875749824.png
https://www.sierrachart.com/image.php?Image=171387593018.png
Date Time Of Last Edit: 2024-04-23 12:39:18
[2024-04-23 13:45:47]
Sierra_Chart Engineering - Posts: 17162
This is definitely something we would not do. Definitively no chance.
The difference is that when you open and close with either OK or using Apply/Cancel the Chart Studies window, the study arrays are getting cleared.
Date Time Of Last Edit: 2024-04-23 13:46:02
