Date/Time: Sun, 24 Nov 2024 22:55:38 +0000
Volume number/1000 on top of volume bars
View Count: 208
[2024-04-23 07:35:26]
User251043 - Posts: 46
I want to display volume divided by 1,000 on top of each volume bar. I could do what I show in the attached file: the volume on top of each bar. But I want to have that divided by 1,000. The problem is: when I use the Study Subgraph Divide, as the result is 277 instead of 277042, the system draws the result at 277 height, that is, on bar bottom.
What can I configure to have 277 number on top of a 277042 contracts bar?
Thank you.
Date Time Of Last Edit: 2024-04-23 07:36:43
imageimagen_2024-04-23_093545156.png / V - Attached On 2024-04-23 07:35:47 UTC - Size: 21.89 KB - 60 views
[2024-04-23 11:04:32]
I found a way to solve this using independent scales. Thank you.
