Date/Time: Tue, 22 Apr 2025 10:14:29 +0000
Reactivating Sierra Chart
View Count: 293
[2024-04-23 06:58:34]
User575872 - Posts: 76
Hi, I'm currently in the process of reactivating Sierra Chart. I have CQG realtime data and trading via CQG / AMP Futures. Can I continue to work with CQG realtime data and place orders with Service Package 10? Of course after payment to my account.
Thank you very much and kind regards
Wolfgang Lucke
[2024-04-23 15:10:35]
John - SC Support - Posts: 39395
First we definitely recommend using Teton order routing if you are trading The CME Group:
If you are trading EUREX you will need to use CQG. Whether you need data for CME Group or EUREX, you need to get the data from our Denali Data Feed when using CQG:
Denali Exchange Data Feed
[2025-01-17 16:38:35]
Hi, is a bracket order with "Move to Breakeven for Stop" set completely on the server (Teton CME order routing, clearing firm AMP)?
Many thanks and kind regards
Wolfgang
[2025-01-17 17:27:12]
With the Teton Order Routing service these orders are kept on our servers and updates are sent to the exchange from our servers.
