Date/Time: Sun, 24 Nov 2024 23:19:45 +0000
Trading Activity Log in 2629
View Count: 203
[2024-04-22 17:18:47]
Tony - Posts: 516
Hi
After I upgraded to 2629, I noticed when I deleted some Trading Activity entries, the entries still appear in the list until I go Edit --> Refresh Log, not like the old versions that those entries disappear right after I select delete from edit menu.
I first thought it was WINE issue, then I tested it in Windows 10, same thing happened.
That is not as convenient as the old versions, wonder if that is way it is or there are settings need to be changed?
Thanks so much.
Date Time Of Last Edit: 2024-04-22 17:19:27
[2024-04-22 19:40:28]
Sierra_Chart Engineering - Posts: 17163
We will check on this.
