Date/Time: Sun, 05 May 2024 08:50:53 +0000
5m opening range using initial balance study
View Count: 57
[2024-04-22 14:45:44] |
User504477 - Posts: 15 |
I'm using initial balance study for plotting 5m opening range. It appears the low is painted incorrectly. any idea? |
Screenshot 2024-04-22 074410.png / V - Attached On 2024-04-22 14:44:44 UTC - Size: 45.19 KB - 12 views Screenshot 2024-04-22 074002.png / V - Attached On 2024-04-22 14:44:50 UTC - Size: 6.93 KB - 12 views Attachment Deleted. |
[2024-04-22 14:54:14] |
Sierra_Chart Engineering - Posts: 14228 |
We are not able to help with this. We do not understand your question. When posting an image of a chart it must follow these specifications: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-22 14:54:29
[2024-04-22 15:03:57] |
Please see the screenshots. 5m range low is painted at low of 2nd 5m bar and not the 1st one at NYSE line.
[2024-04-22 15:05:06] |
Never mind. I fixed it by using 6:34:59 for the end time.
