Date/Time: Sun, 05 May 2024 14:39:22 +0000
Moving average behind bars and Arrow at bottom of screen gone
View Count: 46
[2024-04-22 00:09:28] |
User720813 - Posts: 10 |
Hello I have been searching for these 2 answers but i cant find them... 1. How do get the white line (Moving Average) in front of the bars? 2. The arrow at the bottom of the screen which allows you to slide forward or backward is gone, how do i get it back? Thank you very much. |
Attachment Deleted. Private File Private File |
[2024-04-22 15:13:21] |
John - SC Support - Posts: 31362 |
1. For the study that is drawing the white line disable (make sure it does NOT have a checkmark) the option for "Draw Study Underneath Main Price Graph". Refer to the following: Chart Studies: Settings and Inputs Tab >> Draw Study Underneath Main Price Graph (in the same Chart Region) 2. Select "Chart >> Show Scrollbar". Refer to the following: Chart Menu: Show Scrollbar (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
