Date/Time: Sun, 05 May 2024 14:21:56 +0000
Volume At Price Threshold Alert V2 Extension Lines not showing up on TPO chart
View Count: 49
[2024-04-21 21:30:54] |
Ed Levy - Posts: 13 |
Chart Data Type: 1 Minute Candlestick Intraday Chart Volume at Price Multiplier: 1 Inputs: Comparison Method: Ask Volume Bid Volume Difference Volume Threshold: -300 Alert Disabled All Alerts Draw Transparent Range: No Additional Volume Threshold: 0 Enable Zero Bid/Ask Comparisons: No Zero Value Compare Action: Set 0 to 1 Highlight Adjacent Alerts: 0 Draw Extension Lines to End of Chart: Yes Number of Days to Calculate: 360 Subgraphs: All Triggers are Square Offset, although I want to ignore each and will do so after figuring out problem with displaying lines Extension Line Properties: Line, Width 4, no Names or Value Labels The extension lines show up on my Numbers Bars chart but not on my TPO chart. Does this study not work on TPO charts? Thanks, Ed |
[2024-04-22 15:03:30] |
John - SC Support - Posts: 31362 |
It does not work with TPO charts, nor do most studies. Refer to the following: Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart Since you are just wanting the Extension Lines, you can get these to show at the right price levels, but the start/stop will not be correct, as there is not a way to relate the bars from a standard chart to a TPO. To do this, use the "Study/Price Overlay" and set the Input for "Copy Extension Lines From Source Study" to "Yes". You will also want to set the Draw Style for the Triggers to be "Ignore", just remember to change the Input for "Use Styles and Widths from Source Chart" to "No" before you change the draw style. Refer to the following for the Study/Price Overlay: Study/Price Overlay Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
