Date/Time: Sun, 05 May 2024 12:52:35 +0000
[User Discussion] - Necessary to Use Footprint Sierra Chart for Future Dax and Future Nasdaq without order?
View Count: 154
[2024-04-21 14:19:50] |
User785802 - Posts: 5 |
Hi, I am a French citizen with an obligation to declare bank accounts held abroad. I would like to use Sierra Chart with orderflow to only analyze futures in real time, mainly (Dax and Nasdaq). At first, I wouldn't want to use it to place orders. In principle, i need a subscription to Sierra Chart package 11 and a subscription to your Denali Exchange Data Feed data service. So, a monthly subscription of 46 USD. How much do you have to add to have the Denali Exchange Data Feed service, including the future Dax ? On the other hand, at the first sight you must also have an account, to have real-time data, with the broker Stage 5, however they have several offers, which is best for my use? Can AMP or another replace Stage 5? Can you confirm this information for me? Sincerely, |
[2024-04-21 16:10:57] |
Sierra_Chart Engineering - Posts: 14230 |
To receive EUREX and NASDAQ real-time data you do not need an account with a futures broker or any broker. Although, are you referring to NASDAQ stocks? Or NASDAQ futures? Once we get this answer, we will explain the costs to you and exactly what you need. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-21 16:11:44
[2024-04-21 18:05:38] |
Thank you for your reply. Currently, I have a CFD account with IG Europe. The underlying of their CFDs can be an index or a future. However, I want to use Sierra Chart to analyze the footprint. Therefore, I need futures data from DAX and Nasdaq. Sincerely, |
[2024-04-22 14:54:26] |
John - SC Support - Posts: 31362 |
When you refer to the NASDAQ are you referring to the NASDAQ Stock Exchange, so you are wanting the stock data? Or are you referring to the NASDAQ 100 Index Futures that is traded with the CME Group? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-22 15:12:21] |
Hi, I am refering to the Nasdaq 100 Index Futures. Sincerely, |
[2024-04-22 16:01:00] |
Since you are wanting the data for the CME Group, you need to understand the requirement of the CME Group that you have a live, funded, futures trading account in order to qualify for their non-professional exchange fees. Refer to the information here: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges In terms of what broker you can use, the only requirement is that you have to be able to connect your Sierra Chart software to that broker. For instance, you ask about AMP, which we can connect to, so you can use AMP. We are not sure about the question you were asking about Stage 5. If you do not already have a brokerage account that qualifies for the above, then we recommend the solution outlined at the following link: Easy Solution to CME Funded Trading Account Requirement -- Keep in mind that the above only applies to the data for the CME Group. You can get the data for EUREX without the need for a live trading account. You can setup the EUREX data by following the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* -- You will find the prices for the exchanges at the following link: Denali Exchange Data Feed: Supported Exchanges (Exchange Fees) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-30 09:34:44] |
Good morning, I subscribed to Sierra Chart with package 11 without a trading service. However I have the Eurex data ( FDAXM24-EUREX[M]) with a delay. How to get real-time data for Eurex? Should I take out an additional subscription? Sincerely, |
[2024-04-30 15:22:30] |
You have not setup the data for EUREX. Follow the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-01 11:56:22] |
Hello, To have the Dax data in real times, I have to pay $25 per month in addition to the $46 for the package. Is that right? Sincerely, Activating EUREX EOBI. You will be charged 25 USD for the real-time data from the EUREX EOBI exchange from this moment until May 31. You will be charged the 25 USD next month on June 1 unless you deactivate the exchange. Press Activate to confirm. |
[2024-05-01 15:04:19] |
Yes, this is correct. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
