Date/Time: Sun, 05 May 2024 20:20:36 +0000
How do I insta-kill alerts?
View Count: 75
[2024-04-21 06:59:36] |
User740504 - Posts: 61 |
I made a mistake and had an alert set for input filtering on the Time and Sales Window. I got sent around 100 alerts. Shutting down Sierra Chart did not stop the alerts and they would not stop coming. I had to "/detach" via Telegram and that finally did the trick. Is there a way to kill all alerts immediately via Sierra Chart? Edit: Just found "Edit->Disable all Alerts - Chart". Does this toggle "disable" alerts in the Alert Manager (so they won't be triggered) or will it stop any and all alerts being sent out in realtime, effectively killing active ones? Thank you. Date Time Of Last Edit: 2024-04-21 07:04:32
[2024-04-21 11:12:52] |
VLiviu - Posts: 151 |
Ctrl=Alt+Q - global settings - > clear alert sound queue (Under this menu you also have "mute all alert sounds")
[2024-04-21 15:51:41] |
Sierra_Chart Engineering - Posts: 14237 |
If you are referring to alerts that are sent to a Group Chat, once they are sent to the server, there is no way to stop them. Since they are going to be sent instantly. You would have no chance to stop them. Also, we are probably just about a week or so away from releasing our own Web-based/mobile read-only chat program which will receive the alerts. When this is released, you will no longer need to use Telegram unless you want to. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-21 15:52:01
[2024-04-21 17:41:01] |
Thank you both. I'll likely move over to Sierra Chart's built-in chat program and keep things in house in the upcoming week.
