Date/Time: Sun, 05 May 2024 17:37:11 +0000
What Brokers Do You Recommend?
View Count: 139
[2024-04-21 06:56:44] |
User344276 - Posts: 65 |
What brokers do you recommend for Sierra Chart users at this time? Which ones are the most compatible with Sierra Chart? Thanks.
[2024-04-21 16:12:30] |
Sierra_Chart Engineering - Posts: 14234 |
It depends what you want to trade. Futures or stocks or what exactly? Best to tell us the exchanges you will be trading on.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-21 16:12:35
[2024-04-21 17:44:22] |
I will trade futures, specifically the micro NQ and ES, and the emini contracts. Are there any Sierra Charts users that use Amp Futures as a broker without any issues? What are the best brokers to trade micro and emini futures? Thanks. |
[2024-04-22 00:24:08] |
We definitely recommend a broker who supports Teton order routing. They are listed at step 2 here: Sierra Chart Teton Futures Order Routing: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
