Date/Time: Wed, 27 Nov 2024 06:37:20 +0000
linear regression off
View Count: 948
[2014-08-14 17:55:34] |
User57562 - Posts: 98 |
Ctrl-n turned linear regression on, confirmed on Tools menu. How do I turn it OFF? |
[2014-08-14 18:15:15] |
Select Tools >> Pointer.
