Date/Time: Sun, 24 Nov 2024 23:28:43 +0000
Multiple Automatic Batch Sequential Orders
View Count: 273
[2024-04-19 22:21:06] |
Whiskers - Posts: 5 |
Is there a way to create batch sequential orders? For instance, say I'm trying to buy 20 future contracts but instead of 1) placing a single contract order twenty different times manually or 2) placing one order for 20 contracts, is there a way instead to do 3) placing a trade with sequential batch already previously set that would have say 5 single contract orders, 2 two contract orders, 1 four contract order, 1 seven contract order equaling 20 contracts? So, basically a functionality where I could create a batch that I could use each time that would split out 20 contracts to some pre-specified amount that could send out multiple different orders at once like no. 3 above, rather than no. 1 or 2? Please let me know if this doesn't make sense and if more information is needed, thank you. |
[2024-04-20 22:40:12] |
This can be done, but you would have to create a custom study to do it. Refer to the following: Automated Trading From an Advanced Custom Study List of Third Party Sierra Chart Study and System Programmers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-21 23:45:57] |
Ok, thank you very much John, I will look for someone within the third party developer list you provide. Appreciate the quick response.
[2024-04-22 00:12:46] |
Sierra_Chart Engineering - Posts: 17163 |
This is certainly possible to do using ACSIL: Automated Trading From an Advanced Custom Study And then you can trigger the action of sending the orders using one of the methods documented here: Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-22 21:54:42] |
Ok thank you for the additional info. I will read through and reach back out with any questions.
