Date/Time: Sun, 24 Nov 2024 22:29:12 +0000
auto retracement indicator
View Count: 227
[2024-04-19 20:08:28] |
ss1776 - Posts: 11 |
Hi, I am trying to use auto retracement indicator for RTH session. it plots 50% but does not plot 61.8% for some reason would you know why this is happening for me both on nq and es chart? |
[2024-04-19 20:12:23] |
Which Level do you have set to be .618 on the Inputs? Then check the Subgraphs and make sure the level that represents .618 has a Subgraph that is set to display (typically this is set to "Dash"). Let us know what this is set to. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
