Date/Time: Sun, 24 Nov 2024 22:51:44 +0000
AMP account - AMP clears my trades & I use Sierra Charts
View Count: 229
[2024-04-19 18:34:10] |
User469312 - Posts: 97 |
I asked AMP if it were possible for them to enable my trading to trade the Micro Ultra Bond & Micro Ultra 10 YR (MWNA & MTNA) CQG. They said I need to have that data enabled through you? I thought i already have that (CBOT) enabled? I'm confused atm and looking for a little help. |
[2024-04-19 19:59:16] |
Yes, you are setup to get the data for the CBOT (along with the three other CME Group exchanges). We are not sure why AMP pointed you to us first, apart from making sure that you have access to the data - which you do. Check back with them and make sure you are setup to be able to trade those instruments with CQG and let them know that you are setup to get the data from us. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
