Date/Time: Sun, 24 Nov 2024 22:52:18 +0000
Chart Dom/ trade Dom line
View Count: 348
[2024-04-19 17:27:52]
Vasudev - Posts: 7
Hi Team,
I want to display moving average line on Dom but I am not able to do so. I am able to get name/ value text on the label column of Dom but I want to have just lines. I have read the instructions for study overlay but it is not working. As per the below post I should be able to make the lines. Can I add same studies from different time frames onto one DOM? Can you please let me know how to get the moving average line. Thanks
[2024-04-19 17:34:42]
Yes, you should be able to view the line on the Trading DOM using the Study/Price Overlay.
Is the "Study/Price Overlay" set to display in "Region 1"? Refer to the following:
Chart Studies: Settings and Inputs Tab >> Chart Region
Make sure the color and size are adequate that you can view the line. You may want to make the line large to start to ensure you are able to view it and then you can back it off. Make sure you either change the original study, or you modify the settings for the Study/Price Overlay to change these items in the Study/Price Overlay directly. Refer to the following:
Study/Price Overlay Study: Use Colors from Source Study
[2024-04-19 20:59:31]
Vasudev - Posts: 7
Hi John - I already followed the steps mentioned in the study price overlay and i can confirm that the chart region is already set to 1. I have tried to adjust the width but it is not working for me. Can you please let me know if i am missing something. i have attached screenshot below
https://www.sierrachart.com/image.php?Image=1713560254989.png
[2024-04-20 22:33:26]
The line is showing properly, it is just that what you are seeing a large number of bars for the study. Use the Page Up button when the Trading DOM is the active chart to "spread" the Moving Average out to a level that you want to actually view.
Date Time Of Last Edit: 2024-04-20 22:33:39
