Date/Time: Wed, 27 Nov 2024 08:52:29 +0000
combining 2 charts into 1 window
View Count: 2702
[2014-08-14 17:23:23] |
User77503 - Posts: 48 |
how can I attach one chart to another window that is not the main window? the main one has the "attach/detach" function but the other ones dont.
[2014-08-18 08:29:47] |
Here is the documentation for detaching and attaching charts: https://www.sierrachart.com/index.php?page=doc/doc_DetachingandAttachingChartWindows.html If you want to combine more than one main price graph into a chart window, then use the Overlay (Bar) study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s100 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
