Date/Time: Sun, 24 Nov 2024 23:12:56 +0000
Trade Activity Log shows fills while deleted from Sierra
View Count: 243
[2024-04-19 15:04:34] |
tomas262 - Posts: 141 |
That is strange. SC is showing fills despite I deleted all records for the period 18-04-2024 7:30:00 to 18-04-2024 8:29:59 Before delete I could not even match fills chart VS log. Very odd |
2024-04-19_17-01-55.png / V - Attached On 2024-04-19 15:04:28 UTC - Size: 176.34 KB - 64 views |
[2024-04-19 17:04:01] |
That particular line you are referencing is informational. What exactly is it stating?
[2024-04-19 17:34:09] |
there are no records ... I deleted everything between the time range mentioned as you can see in the log but the chart still shows the fill ... the fill should not be on the chart at all Date Time Of Last Edit: 2024-04-19 17:42:08
[2024-04-19 21:31:49] |
Sierra_Chart Engineering - Posts: 17163 |
Are you sure that you are looking at a fill on the chart? We just want to be sure. This should not be necessary but go to Chart >> Chart Settings and press OK to reload the fills. And double check that the fill is actually not in the Trade Activity Log. If that fill you see does not exist, it will no longer be on a chart once the fills are reloaded on the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
