Date/Time: Sun, 24 Nov 2024 23:56:29 +0000
Discrepancies in GDI Drawings Output with OpenGL Enabled/Disabled in Sierra Chart
View Count: 610
[2024-04-19 13:01:17] |
gcUserStudies - Posts: 106 |
I am currently using Sierra Chart version 2629 and have encountered a discrepancy in the output of GDI drawings when OpenGL is enabled compared to when it's disabled. Example, when compiling and running the included GDIExample.cpp file, it displays different when enabled vs disabled. My question is whether this variance in output is expected behavior, or should the GDI functionality produce consistent results regardless of whether OpenGL is enabled or disabled? Thank you. Please see attached screenshots for example. When OpenGL disabled, the second rectangle should be hollow. But it's now filled. Date Time Of Last Edit: 2024-04-19 13:02:45
GDIExample_OpenGL.png / V - Attached On 2024-04-19 13:00:15 UTC - Size: 49.85 KB - 144 views GDIExample_OpenGL-Disabled.png / V - Attached On 2024-04-19 13:00:23 UTC - Size: 49.92 KB - 125 views |
[2024-04-19 15:13:36] |
Sierra_Chart Engineering - Posts: 17163 |
We will look into this.
[2024-05-01 15:12:51] |
We are not able to reproduce this. The second rectangle in the lower right is not filled when using GDI or OpenGL.
[2024-05-01 22:16:45] |
Thank you for looking into this. Here is a screen recording for reference showing the differences I'm having with OpenGL enabled/disabled. I had another person test this and they are getting the same results. Just trying to confirm this is expected behavior or not. Thank you again for your time. |
OpenGL Example.gif / V - Attached On 2024-05-01 22:15:46 UTC - Size: 1.98 MB - 85 views |
[2024-05-02 12:50:29] |
User339987 - Posts: 13 |
Please refer to this post: GDI Brush not working properly |
[2024-05-02 14:24:52] |
LudaTrades - Posts: 26 |
I am seeing the same discrepancy with GDIExample.cpp, attached image
GDI_OpenGL_Discrepancy.png / V - Attached On 2024-05-02 14:24:15 UTC - Size: 58.49 KB - 104 views |
[2024-05-16 18:42:11] |
Hello, Sorry to bump this but I have had a few people test and able to replicate the issue. Can you please check it over again? Thanks |
[2024-05-17 13:49:59] |
And you are having this issue on the latest version of Sierra Chart?
[2024-05-17 14:16:24] |
I just downloaded and tested with 2639. Yes, the same issue still exists. Let me know what other information would be helpful to provide. Thank you. |
[2024-07-08 16:41:42] |
We cannot allocate further time to this. We are unable to reproduce and we cannot allocate any further time on this. It is just the way it is.
[2024-11-17 01:50:29] |
User806065 - Posts: 2 |
Is there a solution for this? I'm running to the same issue on the latest version of Sierra Charts.
[2024-11-17 03:52:37] |
Not at this time.
