Date/Time: Thu, 02 May 2024 10:19:26 +0000
Stops and Targets being modified without user input
View Count: 63
[2024-04-18 23:28:56] |
cocainesquirrel - Posts: 1 |
I have "Adjust Attached Orders to Maintain Same Offset on Parent Fill" set to "No" in General Trade Settings > General. But when trading the orders are being changed, and in the trade log I am seeing "Modifying Attached Order from parent fill" for my targets and stops. What am I missing? |
[2024-04-19 01:36:29] |
Sierra_Chart Engineering - Posts: 14173 |
Teton order routing does adjust the attached orders on the server to maintain the same offset on a fill. It does have the ability to follow that setting from the client side but it is not fully implemented yet. We will work on this but allow about 30 days. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-19 01:37:23
