Date/Time: Thu, 02 May 2024 06:59:07 +0000
Can't update Sierra software
View Count: 59
[2024-04-18 17:41:09] |
jms - Posts: 1 |
Good afternoon, I am receiving errors when updating the software to its current version. "Error opening sierrachart_64.exe. Thank you, Jose |
[2024-04-18 20:43:22] |
John - SC Support - Posts: 31293 |
Please redo the update and after it fails select the button at the top for "Send Log to Support". Then let us know in this thread that you have done this.
[2024-04-18 21:24:46] |
Sierra_Chart Engineering - Posts: 14173 |
Also, try using the ZIP installer: Software Download: Sierra Chart Zip Installer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-18 21:24:58
