Date/Time: Sun, 24 Nov 2024 22:48:04 +0000
can I link both Apex and Topstep to sierra charts and copy trade them?
View Count: 946
[2024-04-18 08:11:57] |
ShaiVardika - Posts: 13 |
hey i have funded live account for the data and i currently trade PA accounts with apex throuh tradovade and use sierra chart for charting is possible to connect them to SC and trade via SC? also is it possible to connect Topstep's accounts aswell and copy trade all together? if so how can i do it? thanks |
[2024-04-18 14:39:56] |
is possible to connect them to SC and trade via SC? It is our understanding that you can not connect Sierra Chart with Tradovate. But double check this with APEX. Another option would be to use APEX with Rithmic and then you can connect your Sierra Chart to Rithmic. Refer to the following: Rithmic Trading Platform Service: Setup Instructions also is it possible to connect Topstep's accounts aswell and copy trade all together?
TopStep also uses Rithmic, so you can connect using the same instructions above. You can not copy the trades between different services. Refer to the information at the following link for how our "Order Allocation to Trade Accounts" works: Order Allocation to Trade Accounts -- If you are connecting to two different services (APEX and TopStep), then you will want to have two separate installations of Sierra Chart in order to be able to have both actively connected to each service. Refer to the following for how to install a second Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-18 15:57:59] |
okay thanks i will check that, lets say i connect Apex with rithmic, once it conncected - do i still get the Data from my live account(i have stage 5 account for Data)? or do i get it from rithmic? |
[2024-04-18 17:16:53] |
As long as you have the option for "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds" set to "Yes" then you will get the data for the activated exchanges on our Denali Exchange Data Feed. You can get the data to three different installations at the same time on a single computer. Refer to the following: Denali Exchange Data Feed: Connections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
