Date/Time: Sun, 24 Nov 2024 23:12:46 +0000
Indicator break at the start of a new session.
View Count: 180
[2024-04-18 07:14:09]
User701530 - Posts: 9
Im using the volume profile study. I have it set to start a new profile at the start of a new session and a separate profile for the evening session. Is there a way for the lines for the POC and high value areas to stop and start again when a new profile is made instead of of being connected? It would look much cleaner without the vertical/ diagonal lines.
[2024-04-18 14:28:09]
Set the "Draw Style" for those subgraphs to "Dash" instead of "Line". Refer to the following:
Chart Studies: Dash (ACSIL: DRAWSTYLE_DASH)
