Date/Time: Thu, 02 May 2024 00:31:10 +0000
Different Values Using TPO & Volume Value Area Lines Studies on TPO Chart
View Count: 61
[2024-04-17 23:00:34] |
User688525 - Posts: 189 |
Hello Sierra Chart, I will need to investigate further, however, if using the "TPO Value Area Lines" and/or "Volume Value Area Lines" studies on a TPO chart, the values are different. I have confirmed that session times, profile times, etc., are identical, however, the levels are still different. Is there a setting or configuration that I may be overlooking? I would like to display full session TPO and/or volume value area lines on a TPO chart that has multiple profiles. Thank you |
[2024-04-18 14:10:27] |
John - SC Support - Posts: 31293 |
You can not use the Value Area Lines study on a TPO chart. You would have to setup the Value Area Lines study on another chart and then use the Study/Price Overlay to overlay it on the TPO. Refer to the following: Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-18 23:03:45] |
Hi John, Thank you for confirming and providing a solution. |
