Date/Time: Sun, 24 Nov 2024 23:12:35 +0000
TAL - Trade Activity populates Trade Data BUT Trades Tab is Empty (Sub Instance)
View Count: 256
[2024-04-17 18:54:05]
User631345 - Posts: 34
Hi John / Sierra,
As a part of my Testing I have been trading in SIM in a separate Instance (ie NOT Main Instance)
Following is my Issue:
"Trade Activity Log" when opened in the Sub instance where the Trades were done from populates the Trade Data in "Trade Activity Log" but does NOT populate data in the "Trades Tab"
Can you please kindly suggest and guide accordingly
Kind Regards
Trade Activity Log_Display Settings
Trade Activity Log_Trade Activity Tab_HAS DATA
Trade Activity Log_Trade Tab_EMPTY
imageTrade Activity Log_Display Settings.PNG / V - Attached On 2024-04-17 18:52:52 UTC - Size: 84.43 KB - 66 views
imageTrade Activity Log_Trade Activity Tab_HAS DATA.PNG / V - Attached On 2024-04-17 18:52:58 UTC - Size: 585.1 KB - 71 views
imageTrade Activity Log_Trade Tab_EMPTY.PNG / V - Attached On 2024-04-17 18:53:04 UTC - Size: 74.77 KB - 66 views
[2024-04-18 17:33:43]
Sierra_Chart Engineering - Posts: 17163
Maybe the tab is disabled. Refer to:
Trade Activity Log: Edit >> Disable Statistics, Trades, Period Tabs
Date Time Of Last Edit: 2024-04-18 17:33:49
[2024-04-19 16:23:30]
Thanks for the prompt reply. Yes works now after unchecking the Disable Statistics, Trades, Period Tabs
Much appreciated
Kind Regards
