Date/Time: Sun, 24 Nov 2024 23:09:49 +0000
How to get rid of an empty void on DOM
View Count: 195
[2024-04-17 16:32:42] |
User701530 - Posts: 9 |
Why is there a large empty void on my dom and how do I get rid of it?
[2024-04-17 17:03:16] |
You must have a column displayed there. Refer to the following: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-17 17:38:35] |
I don't.
[2024-04-17 18:18:19] |
If the item to the left is a "Volume by Price" study, then set the Input on that study for "Align to Far Right" to "Yes". This will shift that item over to be next to the DOM. If the above is not the solution, then we would need an image of your chart so we can see the entire chart. Please get us an image by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) When we get a partial view of a chart, it is very hard for us to determine what is occurring. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
