Date/Time: Sun, 24 Nov 2024 23:10:33 +0000
Open Files On Startup: Delayed
View Count: 229
[2024-04-17 14:45:37] |
User538960 - Posts: 29 |
Dear SC Support Team, I noticed earlier this week that the function "Open Files On Startup" is delayed. In the past, the chartbooks I had in the associated list opened immediately as soon as the main SC window was open after starting the platform. Now it takes more than a minute before the chartbooks get opened automatically. I hope you can do something about it in order to make it faster again? (I'm on SC version 2627.) Thank you. |
[2024-04-17 19:20:38] |
Sierra_Chart Engineering - Posts: 17163 |
There has always been a delay, with opening Chartbooks. If there any files that need to be downloaded, those will be downloaded first. There is a delay until the data feed is connected. All of this is normal. Make sure Sierra Chart is set to connect to the data feed on startup. This is not version specific at all. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-17 19:20:53
[2024-04-17 20:05:29] |
In case file downloads are causing a problem, disable them here: https://www.sierrachart.com/UserControlPanel.php?page=EnabledCustomStudies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-18 09:36:25] |
Well, I have been using Sierra Chart for years with the "Open Files on Startup" function, and it has always instantly opened the charts as soon as the platform opened and the data feed was connected. That it takes more than a minute now is new and definitely not normal. But who knows, maybe the delay is caused by one of the other files that - as you mentioned - are downloaded prior to the chartbooks, for whatever reason. But I can't disable them, because I need some of the studies contained in them. Anyway, thank you for your feedback. Date Time Of Last Edit: 2024-04-18 09:37:16
