Date/Time: Sun, 24 Nov 2024 23:06:34 +0000
Study: Number Bars Calculated Values
View Count: 225
[2024-04-17 13:35:22] |
7080551385 - Posts: 15 |
In regards to "Number Bars Calculated Values", for the "Column(x) Background Type" I can only find Ask Bid Difference Profile but I can not locate something like Ask Bid Diagonal Difference Profile - I wanted the bar profile to calculate in diagonal difference. Can you enlighten me if this is available? If not, I would much appreciate it if you can add this to this valuable functioning feature for this particular chart study. Thanks. |
[2024-04-17 16:18:35] |
The option you are looking for is not available. We have noted this as a Feature Request. We can not say when we would get to any particular request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
