Date/Time: Sun, 24 Nov 2024 22:52:21 +0000
Lost my Mornings Work
View Count: 216
[2024-04-17 11:01:39] |
bobstone249 - Posts: 28 |
I've been using Sierra Charts successfully for months with no issues. Just lost my entire mornings work. Sierra charts chartbook closed down with no prompt to ask if I wanted to save the chartbooks. Lost about 3 hours work. Really unusual for Sierra charts and now I'm quite concerned. No issues this end with connectivity etc.
[2024-04-17 16:13:42] |
Check this setting and makes sure it is set to "No": Global Settings >>General Settings >> GUI >> Disable Prompt to Save Chartbook on Chartbook Close And always Save your Chartbook manually, after a significant amount of changes. Also refer to: Chartbooks (Workspaces): Accessing a Backup Chartbook File There is also automatic save functionality: General Settings Window: Auto-Save Chartbooks (Global Settings >> General Settings >> Charts >> Chartbooks) If you are referring to an abnormal shutdown of Sierra Chart, then refer to: Sierra Chart Unexpectedly Shutting Down | Memory Errors | Unusual Software Problems | Exception Errors | Freezing of User Interface For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
