Date/Time: Sun, 24 Nov 2024 22:41:33 +0000
Volume At Price Threshold Alert V2 stacked imbalance
View Count: 226
[2024-04-17 10:51:59] |
User251851 - Posts: 2 |
hello, in the setting of Volume At Price Threshold Alert V2, for the stacked imbalance we can have the draw of the highest or lowest price of adjacent alerts when i want to have the price of the highest price of the stacked imbalance it's ok using sg50 but how to get the lowest price of this imbalance ? thank you |
[2024-04-17 15:57:59] |
SG49 (Subgraph 49, "Adjacent Alert Highlight Bottom") will have the information for where the bottom of the stacked imbalance is located. The one trick with this is that SG49 always has a value, so you can not use it alone and know that it is a Stacked Imbalance or not. Depending on how you are using this, it may be something you have to think about. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
