Date/Time: Sun, 24 Nov 2024 23:56:51 +0000
Large Volume Indicator as reference
View Count: 265
[2024-04-17 09:12:40] |
rtinada - Posts: 4 |
Hi Team, 1. Is there any way that I can use values from Large Volume Indicator in my custom study (I'd like to use number of occurrence from LVI study) So let's say in LVI I set threshold = 5, I'd like to calculate how many occurrences with this threshold were in a specific period, and I d like to sum up the volume of total orders that LVI return 2. Is there other way to achieve point number 1 without using ASCIL? Regards, Adam Date Time Of Last Edit: 2024-04-17 15:48:12
[2024-04-17 15:49:39] |
Unfortunately the information you are wanting is not available. This particular study does not store the data for each bar in a subgraph, therefore the data is only available internal to Sierra Chart.
