Date/Time: Sun, 24 Nov 2024 23:25:31 +0000
Request for new formula under study Pivot Points-Variable period
View Count: 188
[2024-04-17 08:08:13]
RAVENOUS - Posts: 3
I ask if it is possible to add a formula to the study "Pivot points - Variable periods" that shows as pivots the previous low (0%), 25%,50%,75% previous range, the previous high (100%) and extensions every 25% by the high and low part of the previous range.
[2024-04-17 13:36:50]
Sierra_Chart Engineering - Posts: 17163
We recommend you create your own custom study to do what you need.
Also have a look at this page:
Using the Basic Arithmetic Studies
