Date/Time: Sun, 24 Nov 2024 23:56:25 +0000
[Programming Help] - Enable and Disable Studies using ACSIL
View Count: 261
[2024-04-17 07:57:35] |
User582682 - Posts: 3 |
I've looked around on the forums, but I haven't seen anyone mention it yet. Is it possible to enable and disable other studies using a study with ACSIL? If the above isn't possible can you add and remove studies using ACSIL in another study under specific conditions? Update: It looks like I can add and remove studies. I just have to figure out how to do this for custom studies. I don't believe there is a way to enable/disable existing studies on the chart. I've figured out how to do this for custom studies. For anyone looking you can find documentation here: sc.AddStudyToChart() Date Time Of Last Edit: 2024-04-18 01:59:21
