Date/Time: Sun, 24 Nov 2024 23:16:46 +0000
Trading activiity log not displaying correct time
View Count: 228
[2024-04-17 01:07:37] |
User905404 - Posts: 1 |
Hello, Im trying to export my trade activity log into an analyzer program (tradezella) and the date is fine but the transaction time in and out is not correct ( i beleive is on utc time). i have my global setting set at new york time. is the a way to correct this? thank you for your assistance Mike |
TradeActivityLogExport_2024-04-16-222.txt - Attached On 2024-04-17 00:32:18 UTC - Size: 10.93 KB - 248 views Attachment Deleted. thumbnail_IMG_3095 (1).jpg / V - Attached On 2024-04-17 00:51:16 UTC - Size: 129.12 KB - 61 views |
[2024-04-17 15:34:48] |
This is correct, the time is in UTC. When you export the Trade Activity Log it will be in UTC time. This allows the data to be imported into Sierra Chart. You can use the "Save" option instead, which will save the information using the time that is displayed. Refer to the following: Trade Activity Log: Saving to a Text File For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
