Date/Time: Sun, 24 Nov 2024 23:31:44 +0000
[User Discussion] - toolbar
View Count: 273
[2024-04-16 20:46:33]
renzo schiavo - Posts: 2
buongiorno
Aprendo Sierra Chart non mi appare la toolbar. Come posso attivarla?
Grazie e saluti.
Renzo
[2024-04-16 21:03:53]
From Google Translate:
When I open Sierra Chart the toolbar does not appear. How can I activate it?
Thank you and greetings.
We assume you are referring to the Control Bars. As such, refer to the following for how to display a Control Bar:
Control Bar: Window >> Control Bars >> Control Bar [1-12]
Once you have a Control Bar displayed, it will stay there when you open/close Sierra Chart.
Also make sure you read through all of the information in the link above, as there is information on why a control bar may not display.
Date Time Of Last Edit: 2024-04-16 21:04:08
