Date/Time: Sun, 24 Nov 2024 23:28:31 +0000
Re-run trade results using internal SIM
View Count: 265
[2024-04-16 18:20:50]
User290496 - Posts: 62
Is there some way for me to to the following-
I have thousands of trades that have been taken in SierraChart's internal SIM on a specific SIM account (e.g. Sim #8).
There was one 'Trade Window Configuration' used for this- using predfined take profit targets, multi-step stop loss trailing etc.
I have now modified the logic for the take profits and stop loss trailing etc- and saved it under a new 'Trade Window Configuation' name.
Is there some way to re-run all- or part- of the trades taken on this particular SIM account- and have it apply the new Trade Configuration so that I may instantly see how the results would have changed with the new take profit and stop parameters?
Cheers
[2024-04-16 20:01:16]
Run a replay and enter the trades as you did previously. Just make sure the new configuration is selected. Refer to the following:
Replaying Charts: Basic Chart Replay Instructions
[2024-04-16 20:09:14]
I had done these trades manually in replay mode using a SIM account. I never 'entered' them in anything, I took the trades on the chart during replay.
It would take many days to redo those thousands of trades again in replay.
Is there a way to copy the trades into another SIM account and have the system switch the configuration used to the new one- so results can be seen using the new configuration?
Or anything similar?
Basically- looking for a way to see how the results from these thousands of SIM trades would have changed using the new trade configuration.
Date Time Of Last Edit: 2024-04-16 20:09:59
[2024-04-16 20:35:18]
There is not a way to do this using the built-in tools. You would have to create a custom study that reads in the orders and then places a new order at the time that the previous order was entered. Refer to the following:
Automated Trading From an Advanced Custom Study
List of Third Party Sierra Chart Study and System Programmers
